Hi new here
D R Oldfield
Barrow-in-Furness
Hi just to introduce myself just board a z3 2,8 1998 as a weekend driver ,absolutely love Bmw my daily driver is a msport x3 2.0 ltr diesel which I also use for work I am a electrical engineer in a water comoany in the lake district in Cumbria so some fantastic driving roads , I also own a Dosmestic appliance repair company and will gladly help any one with advice about problems with white goods etc , I have owned a lot of bmw though mostly have been 3 series tourers
Requards
Dave
Hi Dave and welcome. Keep your eyes peeled for @Andy McDonnell out and about in "Bella"
Slam
North Yorkshire
Zedless. Mini GP 1379
Hi and welcome from London
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Hello and welcome to the forum
D R Oldfield
Barrow-in-Furness
Hi thanks for the warm welcome just got my z3 today 200 miles from Glasgow what a fantastic car though I think I will be needing a bit of advice just paid £1950 for a 2.8 wide bodied z3 130k mlies but drives spot on couple of warning lights on abs and center brake warning light but everything seems to work and passenger side sill is a bit dodgy at the back are these anything anything to worry about ? It does have 11 months mot thought any advice would be appreciated it also appears to have a few sutle msport badges did the make an msport z3 .?
:welcome::welcome:
If you're referring to badges on the steering wheel, gear stick etc. they're quite common mate. Sounds and looks like you have found yourself a nice car. Corrosion on the outer sill covers is quite common, considering it's 20 years old. These are still available from BMW and don't cost an arm and a leg either.
D R Oldfield
Barrow-in-Furness
Are there any known issues with the abs systems the last owner said the lights have been on for a few months but I thought it would have been a mot failure it was moted at the start of June ?
If the ABS light wasn't following it's correct sequence at the time of test then it should have failed the test, but, it is what it was doing "at the time of test" that matters. A common issue is the wheel speed sensors which give problems. Have you got anything to read the codes on the OBC? If not that's your best first option.
It did fail on ABS problem in 2009 Dave.
Date tested 10 June 2009
Fail
Mileage 104,914 miles
MOT test number 3526 9146 9184
Test location unavailable until further notice
Reason(s) for failure
  • Nearside Front coil spring cracked (2.4.C.1a)
  • Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Advisory notice item(s)
  • Nearside Front brake disc slightly pitted (3.5.1h)
  • Offside Front brake disc slightly pitted (3.5.1h)
D R Oldfield
Barrow-in-Furness
Hi I noticed that but the last mot was on June the 6th 2018 but it didn't fail or have any advisories when I looked at the car today the 2 warning lights were on and had been for several years ,he said he had a auto electrician look at it and had said it was a wiring fault but I thought it was worth a gamble considering what I paid for it I don't have any way of reading the codes but thinking I better get some thing is there any thing that will read both my z3 and my 2006 x3 ?
Thanks
Dave
TBH I'm not sure about that Dave. Someone will correct me if I'm wrong but I think INPA would read both cars?
Bazza
Verwood Dorset
:welcome:from me:highfive:
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:welcome: Hi and welcome to ZroadSter :coolsteer)
