Have a look on YouTube there are loads of informative videos. This is just one of them.Bummer...was hoping for some help here. Tried to pull it off but it started to come apart and a tiny torx screw (like really tiny) fell out. I could see another in there as well, but there is no way you could get to them with it in place.
I don't want to ruin them, but I'm stalled out until I figure it out. I'm supposed to go to an event Saturday....was hoping to have the new wheel on, but may have to pull it and reinstall the original.
Yep....I've watched a bunch of them, but none address those trim pieces. Interestingly, none address the plastic piece on the back with the ribbon cable either. They say how to remove the airbag module and the bolt and gloss over everything else.Have a look on YouTube there are loads of informative videos. This is just one of them.
View: https://youtu.be/hn7pMB4gyJs
You didn't get as far as this one then?Yep....I've watched a bunch of them, but none address those trim pieces. Interestingly, none address the plastic piece on the back with the ribbon cable either. They say how to remove the airbag module and the bolt and gloss over everything else.
Great vid Tony, pretty much confirms what I said in post #2.
Tony - thanks. I did not see that one. Clearly your google fu is better than mine. I looked at a lot of vids and most were just pulling the wheel off and installing an aftermarket wheel or a different BMW wheel. I appreciate the help. They did indeed pull off, but not without damage. There's a top piece and one underneath held together with super small (like jewlers size) screws and one side flexed enough coming off that they stripped out 4 of the 5 screws and came most of the way apart. I was able to re-install the screws with a little glue and get the new wheel reassembled. I can't see much reason for them to be two separate pieces except that maybe they re-use the bottom part of it for wheels with controls on them, so they can screw on the top with buttons or the plain one that's on my Z.
