Hi,
Recently my car has been intermittently making a strange grinding noise. It's coming from the front and sounds a bit like metal vibrating on metal, or like a washer is loose vibrating in a tin? Almost like a grinding gear.
It was a little low on oil so I topped it up and thought it was gone.
I have done about 100 miles since then and was driving round this morning and it was fine. Then went into the supermarket, came back out and it was back!
I drove home, opened the bonnet to investigate, couldn't find any solution, so turned off the engine removed the key, then just out of interest tried starting it again and it wouldn't? I pumped the accelerater a bit and it started. So to test again I repeated and it wouldn't start again?
I am so confused as to what this issue is? Has anyone any ideas?
I'll post a video in the morning if it is still making the noise.
Thanks again for the help in advance.
Connor.
Connor.
