hawkeysr
- Joined
- Nov 2, 2020
- Points
- 28
Hi all
I have been having a strange issue for a while where on a long drive the temp gauge will drop from the middle down to cool and then slowly back up again and repeat, doesn’t do it all the time just occasionally. So with this in mind I decided todrain the coolant and replace the thermostat (eurocar parts jobbie). I never have any loss of heater function in the car when this happens?!?
So new thermostat fitted, coolant filled and then more problems started. I filled the coolant with the heat on hot and setting 1 as advised and the car heated up to the middle and had not hot heat inside the car.. took it for a long drive came home and pulled up in the drive stopped the engine and I could hear water splashing
Opened the bonnet and coolant was blowing out of the cap, well the underside of it. I unscrewed the valve and let the air out ... well steam and the coolant leak stopped.
let the car cool down and topped it back up, ran the engine to get any air out and took it in a drive.
came home and same thing, coolant leaking?
Any ideas... I’m starting to think the thermostat is faulty as when you to temp with the bleed valve removed nothing came out? I ran it for about 45 mins and all that came out was steam?
your wise advice much appreciated!?!
