TopazedMatty
- Joined
- Dec 20, 2018
- Points
- 14
Hi,
As promised, here is my first technical post. Let's see what damage I've done
As part of my heated seat swap (a bit of a disaster because my Facelfit car has pre-facelfit seat wiring loom - I'll post a new story on that when I've solved it), I had to find the heated seat dash switch connectors, that form part of every seat wiring loom, irrespective of whether heated seats were fitted at the factory. Lot's of forum advice on where these devils could be hiding. Some folks report them floating around visibily under the gear gaitor, others report them rolled up tidally behind the console and others report them tucked underneath various bits of carpet. I guess it might depend on how many "improvements" have been made by PO's and how many times the dash bulbs have been changed etc etc. Anyway, mine were well hidden behind the console, under the carpet. After much scraping of skin, I found them. I wasn't expecting them to be purple for a start! (re facelift / pre-facelift). I had to tug (gently) to get them free and all of a sudden I had dozens of "spare" connectors staring at me - well 5 anyway along with a wire with working bulb, presumably for the dash heater controls or something (i seem to remember previously thinking a bulb must have blown).
Cut a long story short, can anybody identify some or all of the connectors/plugs in the photo? - I can't believe that none of them need to be plugged in somewhere. As you can see from the photo, the switches are now in, in place of the blanks that were there. The battery is currently disconnected because the seats are still out of the car, so I can't fire the old girl up to see what is and isn't working. I don't want the SRS dash light to come on and need resetting. Everything was working before I started messing about by the way.
Any help would be greatly received.
Cheers, Matt.
Cheers, Matt.
