Hi all
I’m after some help I’m getting rather confused!
I have a 1998 1.9 m44
The main issue I have is with the abs. I would have a very intermittent fault with the abs light coming on. If you restarted the car, the light would go off and stay off for some time.
It’s now pretty much on all the time.
I’ve scanned codes and have this (pics at bottom)
I know these suffer with the pump ecu solders going bad..and think this may be the issue here?
If so, can it be repaired, or replaced…where would o find the part number? I also get the impression any pump change, the pump has to be “coded” to the car?
Also whilst scanning I got a “70 camshaft position sensor”..I’ve deleted this code before.
The issue here is that there is no check engine light and the car runs ok, albeit a lumpy idle.
My question here concerns the replacement sensor. I would love to go down the bmw genuine route..but nearly fell off my chair when I saw the price..nearly £250! Is this the only route, as I’ve seen some meyle or Bosch ones advertised more sensibly?
Any advice greatly appreciated!
Thanks
Danny
Thanks
Danny
