Help identifying part pls
Discussion in 'Z3 Roadster & Coupé' started by DrWong, Sep 9, 2019.
  1. DrWong
    DrWong Zorg Addict
    May 8, 2017
    435
    190
    57
    Model of Z:
    3.0i
    Evening Brain Trust:)
    Got sills and liners off to de-rust and paint front arches and chassis rails. Noticed this little guy looking a bit sorry for himself and letting the side down a bit. Would like to replace him but have no idea what he is. Looked on RealOEM but none the wiser.
    Can anybody help? I’m presuming the green highlighted strap and bolts are separate from the main red highlighted bit?
    Also, can anybody tell me if the two little studs holding the bracket for the front bumper (circled in photo) will come out the chassis, or are they welded in?
    Thanks in advance:drinks:
  2. spurs fan in a coupe
    spurs fan in a coupe Zorg Guru (IV)
    2,777
    1,987
    165
    Top image is one of the horns
    I don't think the bumper guide bolts come off easily
    • Thank You! Thank You! x 1
  3. mrscalex
    mrscalex Zorg Guru (IV)
    Supporter British Zeds 3rd Party Trader
    Jun 10, 2016
    3,711
    1,817
    150
    The bolts are welded onto the chassis. Be careful when you undo the nuts as you may end up twisting the flange the horn bracket mounts to.
    I bought a brand new pair of Flamm horns and made up a converter harness for the generic blade connectors on the horn to keep the original car end connector. I don't like hacking the car's harness.
    [​IMG]
  4. DrWong
    DrWong Zorg Addict
    May 8, 2017
    435
    190
    57
    Model of Z:
    3.0i
    thanks @spurs fan in a coupe and @mrscalex
    The horns are still working afaik so might take them off, clean and paint them, and then reinstall.
    Would definitely like to replace the metal strap and nut holding the horn to the chassis though. Rob - do you know if those bits are readily available separately from the horn units?
    Noted about the welded studs, thanks for the heads up:thumbsup:
  5. mrscalex
    Jun 10, 2016
    3,711
    1,817
    150
    Sorry no idea on the straps. My horns came with new ones but I used something from my spares box.
  6. Stevo7682
    Stevo7682 Zorg Guru (V)
    Supporter British Zeds Scottish Zeds
    Apr 1, 2016
    5,504
    3,154
    193
    maybole
    Model of Z:
    Individual dakar
    Screenshot_20190911-225549_Chrome.jpg The strap will be part of new horn looks like at some point you could get the brackets shows on real Oem but faded picture means not available and no corresponding part number
  7. DrWong
    DrWong Zorg Addict
    May 8, 2017
    435
    190
    57
    Model of Z:
    3.0i
    Looks like horn brackets are still available on RealOEM, but they're listed under bodywork > front body as per item 10 on this page :thumbsup:
