HELP..!! Cleaning fuel tank without removing it
Mario
Hello
I have this zed I am trying to put back on the road after being in storage for many years.
The fuel pump was seized and then I removed it there's this tar like substance on the bottom of the fuel tank.
Is there any way or product I can use to try clean as much as possible?
I can reach with my hand inside the fuel pump area to clean but this is tank has another lobe/hump behind the passenger seat right? How do I reach there? How clean does the tank need to be?
I am not sure also if there are other books and crannies I should be able to reach from the pump hole. I can also fill the tank with something let it sit so it dissolves and drain as much as posible right?
Thanks guys
Delk
Hemsby Norfolk
Z3 2.8 real widebody
Never had to clean a plastic tank before. I can only think of putting some sacrificial fuel in and sloshing that around a bit before removing it.
