Help/Advice required for Airbag warning light please.
dt7734
Hi Everyone
Just sorted one problem with your help (Camshaft position sensor), cheers guys.
Seems my little Z3 has set me another challenge.
Yesterday I noticed that the Airbag warning light stays on all the time.
I’ve scanned it with my basic OBD 2 fault code scanner but its not showing any fault codes.
Any help or advice would be greatly appreciated.
Thanks in advance.
Dave
Mazza
Bognor Regis
Check ( with mirror and light) that the underseat connections are ok and haven’t separated. The ones that connect to the seat belt anchors.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
You'll need a better scanner to read the airbag codes. There are various BMW air bag scanners on E-Bay.
Once you get the error codes, you'll know were to look.
lucky jim
blaby
z3
Hi Everyone
Thanks in advance.
Dave
hi i bought my car with the airbag light on spent a lot of time trying to find out what was the cause bought a B 800 MEMO SCANNER reset tool that did the trick not been on since .12 pounds ebay
Mazza
Bognor Regis
G4FUJ
Cheltenham
Z3 1.9
And have sold it subject to payment :)
dt7734
I have tried scanning using a streetwise scanner and under bonnet OBD connector as show in the pic but it is showing 'NO ERROR CODES'?
Is my scanner suitable or do I need the B 800 MEMO SCANNER as stated above?
Mazza
Bognor Regis
What’s your location, someone close may have one you could use to clear the light.
dt7734
Update.
Bought a B 800 scanner off fleabay, once scanned it showed 2 fault codes:
38 (Control unit fault, swinging voltage test)
11 (Supply voltage)
Noted this info down, cleared the codes, re-scanned and the light stayed off and remains off after covering more than 100 miles.
No idea why it blipped in the first place but all seems good again now.
bonbon
Israel
19L Auto
"No idea why it blipped in the first place but all seems good again now."
Usually for reaching for something behind the seat and momentarily interrupting the contact.
