Hello people,new to the club,own a 2002 bmw 1.9 z3 and love it.here for advice and tips.
If the EM light has one on you need to get a code reader hooked up to it to read any/all stored trouble codes. Best guess is the inlet cam position sensor has had it. Possibly been changed for a cheap aftermarket item which are worse than useless.Excuse the ignorance here,not quite sure how to use this,my z3 started today but as reversing out drive she cut out and won’t start again plus engine management light has came on ,car is wanting to start but even when I push accelerator pedal it just won’t catch to start,I’ve checked connections on battery and there tight,any advice or idea what the problem might be?
Cheers Tony,I’m located Dundee,il have a look on eBay or AmazonIf the EM light has one on you need to get a code reader hooked up to it to read any/all stored trouble codes. Best guess is the inlet cam position sensor has had it. Possibly been changed for a cheap aftermarket item which are worse than useless.
Where are you located.?, it’s possible there is a member close by who may be able to help with a code reader. Owning a Z3 almost guarantees you will need one sooner or later so have a look on eBay or Amazon.
Thanks for the help,appreciated.Welcome! I would second that it’s the cam position sensor. Dead easy to change on the m43 engine..I think the OEM ones were made by Delphi ..but Bosch would work..buy from a reputable parts supplier! . I am guessing from the number plate you are north of the border ..plenty of Scottish members on here who may be able to give you a hand. I recommend the C310+ code reader. You’ll need the round adapter thingy as well to plug in under your bonnet for anything other than reading the engine codes.
Thanks Ian and Sue and Hello from Dundee,been in my pocket a fair bit with my zed,and hoping this isn’t an expensive fix,I love the car to bits but she’s starting to drain the bank accountfrom North Yorkshire. Hope you get sorted out on Wednesday.
Ian & Sue.![]()
