Danh001
- Joined
- Jun 19, 2022
- Points
- 3
Ever since I bought my 2000 Z3, only the max setting (4) of my heater actually worked. It was fairly easy to find that it was a problem with the blower resistor, of which I confirmed a few months ago. I had been neglecting replacing it ever since as they are going for around £70 on Ebay at the moment.
janijoeli over on zroadster.net has a great how to guide on repairing the heater resistor to avoid paying this crazy cost (https://www.zroadster.net/forum/viewtopic.php?t=38741) however unfortunately, my safety switch is corroded beyond what can be repaired using janijoeli's guide.
Of course to fix this I could simply short the switch terminals but I would loose the safety part of the safety switch. Instead, my idea is to solder a new bi-metal temperature switch across the switch terminals like this one https://www.ebay.co.uk/itm/274479686067?var=574636771799 in hopes of fixing the resistor assembly.
I was wondering if anyone has tried this and potentially what cut-off temperature would be ideal for the bi-metal switch? I have gone with 40degreeC cut-off.
Tomorrow I will pull the resistor to get some pictures.
(Image from janijoeli's guide to highlight the switch in question)
