Heater blower still not working
Rizzo
Oxenhope, West Yorkshire
Following a battery change, I lost the heater fan blower completely doesn’t work on any setting. Having browsed the forum I’ve changed the fuse, relay and today the resister and still nothing. Anything else I should be checking before I change the motor?
I would disconnect the wiring from the blower motor and use a power probe to give it a live feed to see if it will run. A basic power probe is fairly inexpensive these days. When I got mine from Snap-On Tools many years ago they were around £100.
If you can afford to wait a bit you can get the same item direct from China for £16.99.
Here is how to use one , if you didn't know.
View: https://www.youtube.com/watch?v=bTpjv7TKOXI
ps. Lots of test info here.
