So I'm replacing my OEM heated seats with Sparco seat and fitting aftermarket heated seat pads to the Sparcos. So the car already has working OEM heated seat switches and relay and wiring. I am looking to use the OEM switches and not the switches that come with the seat pads. The seat pads are 2 stage heated like the OEM.
I need some help from those who have done this ( I think @Sean d and @Antm72 have done this) as to what wires to connect to what.
OEM wiring and plug under seat 4 wires 2 brown and white/yellow +white/black
OEM switch with 6 wires?
Heated seat pad (2 parts back rest + seat base which connect to one plug)
This has 4 wires (2 green and 2 red/white)
I was planning to use the connector that comes with the kits and cut it and join it to the in car loom so that I have plug. However it has 4 wires: red/white, purple, green, black.
So which do I connect to the cars loom which is 2 brown and white/yellow +white/black?
