Headlight washer retrofit.
jbentley11
I am considering retrofitting headlight washers to my Z3. Does anyone have any photos of the washer flued container showing the relative position of the two pumps and the routing of the pipe through the engine bay towards the front bumper please?
AntStark
Hampshire
2002 3.0 Sport
Headlight washer pump is on the right, windscreen on the left as you look at it from the front
Also on pre face-lift whether you have a tu or non tu engine bottles in different areas.
Stephen.
Ianmc
New Forest
Z3 (M44)
I have headlight washers on my 1997 Z3; about as much use as titis on a bull really. The highlight of the year is watching the MOT mechanic jump out of the way as his assistant tests the screen washers with the lights on!! :D
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
Not a simple thing to retrofit, especially for the benefit they give (none really) IMO.
You will need a new washer bottle, a pump, miles of hose with NRVs in it, either a new bumper or be able to cut the holes in the right places, jet assemblies with colour matched plates, etc. And it will be fiddly to install.
That presumes the wiring is there for the second pump. If not it will be a major headache.
Pond
Spaldingski, Lincs
I have them on the E89 Z4. PITA they are. They never get used, so every year, just before MOT day, I have to test them. Most of the time they get stuck through lack of use and dirt getting in there, as the Z4 ones are hidden behind a plain cover and push out. So have to mess around with them or it is an MOT failure if they don't work!
Ianmc
New Forest
Z3 (M44)
Don't think mine (1997 Z3) are a MOT testable item?
Coded mine out on the e89 years ago, never failed an MOT.
