Headlight/sidelight indication bulb replacement
Chad66Wick
Gloucestershire
Z3 3.0 Sport
Hi folks,
My headlight/sidelight indication bulb has blown. I assume I need to take out the vent to replace the bulb? Any guidance on how best to remove the vent / replace the bulb much appreciated. Looking though the knowledge base, I cant see any previous threads on this. Although, I see a few comments that vent doesn't come out without breaking its catches!!!!!! Any tips to avoid that would be welcomed.
2.2 Sport Individual
If you mean the lamp immediately below the headlight switch it comes out with the headlight switch. No need to remove the vent.
IIRC you remove the top off the knob and there is [I think] an 8mm nut underneath. Remove that then you can remove the knob. You can then remove the screw holding the switch in place, then with a bit of wriggling get the switch [with the lamp] out.
AntStark
Hampshire
2002 3.0 Sport
Worth checking the condition of the headlight rheostat whilst you are at it ..lots of white powder is not a good sign.
... Worth checking the condition of the headlight rheostat whilst you are at it...
The very reason I removed mine to give it a bit of TLC Ant :thumbsup:
Chad66Wick
Gloucestershire
Z3 3.0 Sport
Thanks Mint --- that's helpful!
Chad66Wick
Gloucestershire
Z3 3.0 Sport
AntStark, Thank you on the heads up. Really helpful, as in trying to work out how to get to the bulb I did remove the lower panel below the dash and scratched my head at all the white power sat on it!!!!!! Indeed, so much white powder the Zed might have previously been a Medellín Cartel pool car !!!!! I'll take a long look at the rheostat.....
Love this site --- massive community of knowledge !
ljbmwz3
Lymm
Dakar 2.0
anyone know where to get this replacement bulb ?
Most of the small bulbs like that and heater control ashtray etc are all Bmw only bulbs and are a small fortune for what they are.
Stephen.
