headlamp adjustment
yorky
MK bucks
hi everyone, my z3 has the headlamp height adjuster inside the car, a thumbwheel numbered 0-1-2.
what should this be on for normal uk driving?
i have looked in the manual and cant find anything.
anyone else know?
thanks
anyone else know?
thanks
Hello mate, page 52.
0= 1 or 2 persons, no luggage
1=1 or 2 persons, max luggage.
yorky
MK bucks
thank you so much,
i must have different manual [1997 ] page 52 on mine is interior mirrors.
greeat stuff, thanks for taking the time.
Should be set at "0" before headlight aim is tested on the M.O.T. Test. That is the maximum highest setting and can only be lowered from there. Also, if the tester has to move the control to "0", he should advise the driver/owner that he has done so!
Chrisr1949
Southport UK
Hi, my adjusters doesn't work. I don't know if they're stuck on low or high. The fuses are okay but I suspect the motors. Can't find a how to on remove the actuators, do the headlights need to be removed to unhook the ball? Thanls, Chris
Someone else may be able to give more exact z3 related but in my experience with other models the problem is not so much getting it off and removed it's the trying to get the ball inn the end of the new motor back in the light.
You end up putting your fingers through the bulb fitting hole ( clean gloves required as not to mark it ) and trying to hold the whole lot still while try push motor back on to it .
Zed may be easier never had one off
Bozzy
Long Eaton.
Very useful info that mate. I replaced my off side adjuster motor recently but couldn't get the ball into the socket, so I'll try your tip and see if I can get it back in :thumbsup:.
Always use some sort of lubricant (silicon is best) to locate the ball pin of the adjuster into the lug on the reflector.
Bozzy
Long Eaton.
I put some of that on Tony but still no joy.
The headlight beams are both level though in setting number two.
That may be so Steve but your headlight internals are insecure and will vibrate ( even though you may not see it )
Ever driven towards a car a night and 1 of the headlamp looks like it moves ( vibrates ) afraid that's now you mate .
Bozzy
Long Eaton.
Even driven towards a car a night and 1 of the headlamp looks like it moves ( vibrates ) afraid that's now you mate .
@Stevo7682 again I didn't think of that either.
Just a little update on refitting the headlight adjusters.
To locate the ball on the adjuster onto the socket in the rear of the headlight, it's actually a slotted hole so you can't simply just push it in, as you can on aftermarket ones.
You have to slide the socket in from the left, on the offside lamp at least.
Your tip of removing a bulb, high beam in my case to hold the reflector assembly whilst you locate the adjuster is spot on, thanks :thumbsup:.
Glad that tip has helped you out Steve. :thumbsup:
And so will everybody else that you drive towards at night :whistle::whistle:
Chrisr1949
Southport UK
Thanks for that especially the tip about removing the bulb and confirmation that it does slide in sideways. I need to be able to remove a motor, check it and if necessary refit it whilst I get a new one.
Chrisr1949
Southport UK
I've just made an in-situ test set up for these motors (mine were OK). You will need some electronics knowledge but it is vey simple to make up only requiring a couple of components and a 9 volt battery.
I'll post a how-to in a couple of days
