Hey Guys, You may have seen one of my other posts already im currently in the process of putting my 1997 BMW Z3 back together and I already ordered a ton of parts for it. Anyways my main question is about the head bolts. I already ordered the M10x95mm head bolts and from what I can see they look to fit perfectly fine I stuck one of them through the head to see how far it would stick out and it sticks out a solid 2-3inches which is more then enough to reach the first few threads of the block. But after doing some more research people are saying that I need M10x110mm so the bolt is 15mm longer. Do I really need to get the longer bolts or should 95mm work perfectly fine. I cant seem to find a defintive answer because the 95mm bolts were also used on the M52 and S52 at one point in time and the S52s head is exactly the same as the M52 the only differences are cams. I did check realoem and it seems that I probably should have gotten the 110mm ones instead. Does anyone know if it actually matters? The main reason I got the 95mm is because I saw someone else on a different forum who said the bolts he received were too long and id personally would rather have them short and still be able to work and not too long and not able to be used.
Thanks for the help,
Dre
Dre
