I decided to look at mine, not because there was any obvious problem, but just because the car is 16 years old and made of steel. Am I glad I did! Once the cover sill was off the extent of the corrosion at front and back ends on both sides was alarming. It seems to stretch from the jacking points to the ends in all cases. However, once I had attacked it with a wire wheel on the angle grinder, followed by a small granding stone on the Dremel, I could see that the metal wasn't badly compromised - yet.
I gave the cleaned metal a good soak with Fertan, then when that had done its work, I coated them with Dinitrol underbody wax coating. The cover sills had surface corrosion on the inside, so they were scurfed down and painted with black Hammerite inside. I then used my compressor to spray inside the box section with Dinitrol cavity coating through all the very handy holes.
It's all back together again now and looks no different to what it did before, but at least I know it should last for a few more years now.
