- Joined
- Dec 12, 2020
- Points
- 29
Hello Guys and Girls,
I have a 1999 M roadster with the S50 B32 engine that I purchased about 18 months ago, 98,000 KLM's on the odometer , service records all the way back to new.
I decided to service it myself today as I had the oil light come on a couple of times, just the oil light no rattles and the engine full of oil. When I turn the engine off and restart it the oil light goes off for about 10 minutes so I decided to replaced the oil pressure switch and the constant oil pressure valve (up behind the exhaust). While it is up on stands I thought good time to change the oil and filter. While I was under the car I took the round plate that holds the oil pump filter off the oil pan and I noticed radiator water come out with the oil, about 2 tablespoons worth.
The car doesn't run hot nor does it seem to use water, can anyone shed light on how or where the water could be getting into the oil pan. The oil is not white or frothy either.
Is anyone familiar with this issue?
Cheers
Dave
Cheers
Dave
