Wanted Hard top trim
Justbrowsing
I need the passenger side, black plastic hardtop trim that runs the length of the roof. Happy to buy left/right pair if you don't want to split them.
Are you talking about the rubber seal that goes on either side that the window seals against if so you'll be lucky to get anyone split that.
But if this helps i went to look at a zed just before Christmas cat d but had a hardtop ( needed a few things guy didn't want to budge on his high ish price) anyway the seals on both sides were damaged drivers wrecked leaking water in priced at local dealers still available to order about £40 a side .
If that's not what your after i was talking to the parts guy said most of the bits still available for the hardtop
DavidM
Ireland
It it's the plastic strips recessed into the roof grooves they are very hard to come by - suggest you refer to @Stevo7682 's suggestion - you may be lucky if you are quick off the mark!
mwpe
Camberley
See what Sopers charge. They are held on with double sided tape.
Justbrowsing
It is part 26. I've had one on order with Knights Stoke for about 4 months. They say it's available but can't give a delivery date and the spares guys don't seem too optimistic. I losing hope with getting a new one as everything else I've orders is quite quick.
DavidM
Ireland
It may be worth a try as @Stevo7682 suggests earlier on this post.
