Handbrake cables
Discussion in 'General Banter' started by t-tony, Oct 1, 2014.
  1. t-tony
    t-tony Zorg Expert (I)
    33,097
    15,588
    220
    Model of Z:
    Z4 3.0 Auto
    Well I was at a loose end at work today and we were'nt too busy so I asked my boss if I could fit a pair of new handbrake cables on my car. While I was at it I took the opportunity to fit a set of hub centric wheel spacers which I brought back from California via Florida. (20mm at the rear and 14mm at the front). Also re coated my callipers with another coat of yellow while the wheels were off, would have been rude not to. The old cable "outers" we're both broken so over due for the bin.
    I took a load of pictures to cover the process so if anyone would like me too I will post them later with a run down of the job?:)
    What to do tomorrow? It doesn't look as though it will be much busier.
    #1 t-tony, Oct 1, 2014
    • Like Like x 1
  2. zedonist
    zedonist Guest
    Relax with a cup of tea and a slice of cake.......
    • Funny Funny x 1
  3. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,991
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    Please do post it up.
  4. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,555
    2,580
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    I suspect after 13 years mine could do with changing, ill pop it in tomorrow for you tony :)
    • Like Like x 1
  5. t-tony
    33,097
    15,588
    220
    Model of Z:
    Z4 3.0 Auto
    I do have a pair of (only) slightly worn ones Brian. Special price for a member.=))
    • Funny Funny x 1
  6. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,251
    9,504
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Yes please Tony! If you can post it as a new thread in the Z3 technical section I'll convert it to a wiki article :)
  7. t-tony
    33,097
    15,588
    220
    Model of Z:
    Z4 3.0 Auto
    I'll be pleased to Gaz, you may want to give it the once over first to make sure it's ok? Not too sure how soon I will be able to do it as our daughter Abbie is due to give birth very soon and today was a bit of a sign we think.;)
    Cheers, Tony.
    • Like Like x 1
  8. GazHyde
    Dec 2, 2011
    15,251
    9,504
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    No rush mate, and we can tidy it up if needed...
    • Like Like x 1
    • Thank You! Thank You! x 1
