This arrived I n the post today. A vacuum brake bleeder and fluid mover.
You simply connect an airline to the valve and the tube to the port on top of the bottle. Attach the tube to the bleed screw and loosen, then open the tap and as the air flows through it sucks the fluid from the bleed screw.
Just the same as the fluid remover highlighted by @Andy McDonnell a couple of weeks ago. The one Andy showed does have a hand pump to create vacuum too for those who don't have a compressor. For £13 I thought it was worth a punt.
