zedonist said:
I have them fitted, i have them on the softest setting all round so as per calculation twice the oem stiffness.
I think that a lot of problems can come from the adjustment, and people incorrectly think they should stiffen the rear. This is wrong for a rear wheel drive car as the aim is to keep both driven wheels on the ground, in this case it needs the front ARB to be the stiffest, hence why it is thicker than the rear. On a front drive car you have a stiffer rear ARB to the front for the opposite reason.
Just on the softest setting there is emense improvement in body roll and handling, I also have Bilstein B8 and Eibach springs fitted, sitting on 18inch rims, and I am very happy with the setup and ride.
That's not 100% correct - the aim is to adjust the front to rear roll stiffness balance and deciding what to do really depends what handling characteristic you're trying to dial in/out - it's not necessarily a RWD vs FWD thing.
As a generally rule though yes, a RWD car has a tendency to oversteer, so you would typically soften the rear compared to the front to counteract this and the reverse is true of FWD and most AWD/4WD cars.
However, most modern cars are set up to understeer a bit irrespective of whether they are RWD, FWD or 4WD since this is generally regarded as "safer" and the Z3 suffers a little from this trait too so a little extra rear stiffness (either by softening the front or stiffening the rear) wouldn't go amiss IMHO. However, I certainly wouldn't go too far with this as you don't want the rear to be too mobile on the road especially when you have the bonus of being able to power oversteer rather than relying on lift-over oversteer or some other such provokation.
To the OP, my advice would be as per the other advice above really. The new bars will increase roll stiffness front and rear so you won't really have much of a reference point to start with. Most manufacturers tend to balance the bars in their kits so matching the settings front and rear should give more or less neutral handling which you can then tailor to taste / driving style.
Personally, I'd set both to the softest setting and get used to that. Then start by adjusting the front ARB to see if that improves turn in / the early part of the corner. Once I was happy with the front, I'd then adjust the rear until I was happy with the overall balance of the car (this may mean going back and adjusting the front again at this point too).
The only one that can really says what's best for you and your driving style is you so don't be afraid to experiment. Also, playing with the tyre pressures can allow you to fine tune things between bar settings too (higher pressure to reduce grip, lower pressure to increase it).
