Gummi Pflege
Discussion in 'Z3 Roadster & Coupé' started by alec.m, Jan 15, 2020 at 1:48 PM.
  1. alec.m
    alec.m Dedicated Member
    May 3, 2012
    57
    9
    40
    Lymington Hampshire
    Model of Z:
    3.0 Auto
    Having had issues with water leaks round my windows dripping onto the seat bolsters I`m on a mission to try and sort it especially after yesterdays downpoor which let a lot of water in. Fortunately I put a towel down which caught the worst of it.
    Just looked on ebay and there are two called Gummi Pflege but made by different companies with one being more expensive than the other. Should I be getting a particular brand?
    https://www.ebay.co.uk/itm/Nextzett...080074?hash=item5b408e200a:g:KToAAOSwA3dYh4lt
    https://www.ebay.co.uk/itm/Wurth-Gu...147219&hash=item5b49dcca6b:g:9dsAAOSwjVVVsqGv
  2. Geoff Crispin
    Geoff Crispin Zorg Guru (III)
    Aug 20, 2015
    1,643
    543
    134
    Somerset
    Model of Z:
    3 1.9 & 3.0
    What condition is the rubber item on the top of door ? is it fitted correctly, and one on roof is in good condition.
    Was out in mt 2002 Z3 yesterday and got caught in the very heavy rain and strong wind, no water came in untill i opened the door and the little gutter/seams on the roof could not cope with the amount of rain and it was just pouring over into car:( Geoff
    • Thank You! Thank You! x 1
  3. alec.m
    May 3, 2012
    57
    9
    40
    Lymington Hampshire
    Model of Z:
    3.0 Auto
    Hi Geoff, Thanks for your reply. The rubber seems in good condition . I`ve always had a bit of a drip on the nearest joint to the front of the car but only when it`s been raining heavily. I`ve no idea if the seals are fitted correctly as I`ve nothing to compare it to. I`ve never done anything to disturb them. Alec
  4. Geoff Crispin
    Aug 20, 2015
    1,643
    543
    134
    Somerset
    Model of Z:
    3 1.9 & 3.0
    Alec
    Is the triangle sort of rubber at the top ob bar between window and quarter light seated correctly ? Geoff
  5. alec.m
    May 3, 2012
    57
    9
    40
    Lymington Hampshire
    Model of Z:
    3.0 Auto
    It was last time I looked. I`ll check again though. I`ll tighten the hooks as well, they`re not as tight as they used to be.
  6. Geoff Crispin
    Aug 20, 2015
    1,643
    543
    134
    Somerset
    Model of Z:
    3 1.9 & 3.0
  7. alec.m
    May 3, 2012
    57
    9
    40
    Lymington Hampshire
    Model of Z:
    3.0 Auto
    The ones that fasten the soft top to the top of the windscreen
  8. Geoff Crispin
    Aug 20, 2015
    1,643
    543
    134
    Somerset
    Model of Z:
    3 1.9 & 3.0
    Oh right I call them leavers or catches
    Not sure how you would tighten them though let me know
    • Agree Agree x 1
  9. colb
    colb Zorg Guru (III)
    Nov 25, 2012
    831
    577
    138
    Model of Z:
    1.8
    • Like Like x 1
  10. Paul Rice
    Paul Rice Zorg Guru (IV)
    Supporter British Zeds The M44 Massive
    Sep 7, 2013
    4,112
    2,947
    168
    Doncaster
    Model of Z:
    Z4 2.5
    Clear silicone on the rubber at the end of the A pillars sorted the leak i had on the Z3,
    Wurth Gummi Pfledge 1st class product.
    • Like Like x 1
    • Agree Agree x 1
  11. Christ87
    Christ87 Dedicated Member
    Jun 17, 2019
    68
    51
    29
    Belton, North Lincolnshire
    Model of Z:
    Z3 2.0
    I second that. Helped me out in the past
  12. Mint
    Mint Zorg Expert (I)
    Supporter British Zeds East Anglian Crew
    Sep 23, 2012
    10,263
    6,893
    222
    Staffordshire, UK
    Model of Z:
    1st Z3 | 2.2 | Sport | Individual 2nd - Z3 | 3.0 | Sport
    I've used this stuff for years, it's great for the rubbers. The one I use is the more expensive in your two links....sorry;)
  13. jonco
    jonco Zorg Guru (III)
    Dec 6, 2011
    1,411
    699
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Before you tighten hooks or adjust anything eliminate basic causes i.e. check the A pillar triangular seals. Open roof and fill drainage channel with water then squeeze triangular rubbers - if they ooze water/bubbles through joints then that is your leak path and no amount of Gummi Pflege or tension adjustment will resolve it - they will need re-sealing. HTH
    #13 jonco, Jan 15, 2020 at 10:31 PM
    • Agree Agree x 1
  14. alec.m
    May 3, 2012
    57
    9
    40
    Lymington Hampshire
    Model of Z:
    3.0 Auto
    Thanks, that sounds like the best approach. Hopefully we`ll get some dry weather this weekend!!!!
  15. Nodzed
    Nodzed Zorg Guru (V)
    Supporter British Zeds #ZedShed M Power
    Feb 18, 2016
    6,145
    3,711
    196
    Forest of Dean
    Model of Z:
    Z3M Roadster & e89
    Be careful over tightening the front hooks I have seen these snapped when the roof is closed first time following over tightening, they are only designed to clasp the hood onto the front seal, not to force the hood into the top frame, definitely check the A pillar seals first as said above.
    Also if you decide to adjust the hooks put some WD40 on them first as the grub screw can seize, its tiny, if you round that off you will have a job on your hands.
    • Agree Agree x 2
  16. mrscalex
    mrscalex Zorg Guru (IV)
    Supporter British Zeds 3rd Party Trader
    Jun 10, 2016
    3,676
    1,802
    150
    Gummi Pflege is well regarded and often spoken of in this context. But in my view it's for preventative rubber maintenance. It's not going to stop a leak for you.
  17. Bampz
    Bampz Zorg Addict
    Aug 2, 2016
    466
    118
    59
    Pembrokeshire
    Model of Z:
    2.8
    if the leak is coming from the window perhaps the window needs adjusting to create a better seal against the roof rubbers , I think the window can be adjusted from screws in the bottom of the door , I'm sure someone will correct me if wrong
    • Agree Agree x 1
