After the Rugby ventured out to the garage and did a bit of underbonnet cleaning and pulled the plugs for a clean and check, what a pain in the rear to get the coils out, held in by rubber seals had great difficulty pulling them eventually managed using a screwdriver to help lift them to break the grip the seals were making within the plug wells. Anyone have a better method of pulling them out, using the screwdriver risks breaking the plastic webs around the plug holes.
Loads of dust and grime washed off the inlet manifold and fuel rail, all the plastics cleaned with Back to Black.
Poked the scuttle drain and debris poked out with a fair bit of water draining away. Must check the hood drains next.
Removed the washer bottle and gave that a good clean out. Attention turned to the high level brake light, one end had sprung out, took it out to find its a replacement led unit and it was in three pieces, put it back together using Gorilla tape strips to hold it all together and refitted it.
Ordered some bits in readiness for an oil change including a new Thermal Oil level sensor as I have a code for that, not had time to explore the underside of the car, was planning on checking the wiring to the sensor, if it is duff connection the new part will sit on the spares shelf. Also looking for a AUC sensor Air Quality sensor that sits on the radiator shroud, got a code for that so will check the wiring before I lash out on a replacement, they are pricy. It is part of the Air Con system and looks for bad air, if it sees bad air it switches the air flap to recirculated air in the cabin. Also known as a stink sensor I have found when doing some web research.
Had the computer on it yesterday and checked out the fuel trims in live data, all working as it should. Thought I had an oil leak from the cam cover as there was a small build up of an oily staining on the heat shield over the cat, cleaned that off and have not seen any leak returning, will keep an eye on that and change the gasket if it is leaking. Have ordered a Payen set that includes the round rubber cushion washer for the cover retaining bolts. Did this on Bristol Daves 2.2 a few weeks back and would reccomend putting new ones in if changing the main gasket, New ones are softer and better to use than just replacing the old ones as they go hard and loose their compressability risking cracking the plastic cover if overtightening the retaining bolts.
With all the rain we have had here I am pleased to say the car is dry inside, no hood leaks present, just need to clean and reproof the hood when we get a dry day. Will be washing the hood with natural soap flakes, dry then reproof with Fabsil, have used this on the Z3 with good results.
