Glove Box
OK peeps, a screw fell out of the hinge on my glovebox and it won't bite back in, I take it something has fallen off inside? How difficult is it to take out the panel and front tray please? :arghh:
jonco
Chester
'98 1.9 Auto
Depends how big you are Andy :whistle:It's a tight squeeze between seat and box otherwise it's straightforward.
Extract from another procedure
Stage 1. – Glove Box removal
On my car there are 6 Philips screws holding the box and surround panel in position and you will need to prise the rubber covering caps off to access these. The screws are situated as follows:
No.1- Top left corner – accessed from door jamb - short handled driver or ratchet required, Nos. 2&3 are inside box either side of lock, No4 is in the top right corner and Nos 5&6 at lower right where glove box panel is joined to centre console.
Note: for re-assembly screws 1 and 4 are longer than the other four.
In addition, there is an in-fill panel on the lower edge of the box. To remove this panel, firstly undo and remove the two plastic `push and turn’ plugs, then unclip the panel.
Once all disconnected, gently pull the top left hand side of the box panel forward and then un-hook the right hand lower corner from behind the centre console panel. HTH
Many thanks for the prompt reply, most helpful. Size, no longer a 10 stone chap and with my head upside down my reading glasses rise up above my eyes :arghh:
jonco
Chester
'98 1.9 Auto
Put some padding over the sill or your ribs will keep reminding you of the job.;)
Dino D
Kent
2.8 Manual
I clicked this thread excitedly expecting it would be a 3 page step by step guide on how to use 28 x AG products to clean a Z3 glove box.
disappointed...I’m out:(
