has any one taken there spare wheel and under tray off ,i would like to get rid of mine,is it easy, if so hows the best way to do it.any help would be great .many thanks pete.
:ymcowboy: sMAURICE THE MARTIAN said:Took mine off the z3,undo bolt in the boot ,hinge bolt underneath,then disconnect the lowering handle in the boot,couldnt work out how to do that ,so i just chopped it off s:ymtwisteddevil ,half hr job.
You are correct Gary :-bdGazHyde said:As far as I know not having a spare tyre is not an MOT issue. But oddly if you have a defective spare tyre it is a failure!
TitanTim said:Can these be modified to carry bottles of wine? :-?
Tim. s:lol
I am determined to remove the spare wheel cage as it is 80% rusted and is in desperate need of a lick of paint. :ymsigh:Frank.A said:The lowering cable has a threaded nipple on the end that screws into the end of the cradle bolt.
Remove spare wheel in the usual manner and then raise the now much lighter cradle and unscrew the cable from the end of the cradle bolt. S:smile
Cheers Frank...I'll give it another go tomorrow......more WD40 needed :-bdFrank.A said:In pictures 1 & 2 of your last post,the hexagon nipple on the end of the cable is there to use a spanner on, to release the cable from the mounting bolt. s
At least it is on mine.
