Getrag 250G gearbox oil change
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift
My 98 Z3 2.8's Getrag 250G is due for an oil change
Which oil should I put in?
BMW genuine?
MTF or ATF?
Viscosity?
Brand?
Any help would be much appreciated
Thanks Chris
the Nefyn cat
2.2i Sport
Nothing to do with me, but others have used this lot before.
I would second contacting Opie Oils. They will supply what you need. Also make sure to remove the level/filler plug BEFORE you drain the old stuff. Same goes with the Diff.
And you don't need LSD oil for a Torsen diff.
