Expired GENUINE BMW WIND DEFLECTOR
Synclare
Staffordshire
Another version of BMW's wind deflector for zeds without roll hoops. The brackets simple attach by bolts in pre-drilled holes in the body or depending on year by self tappers if no pre-drilled holes.
The frame pivots in various positions to allow raising/lowering the hood or accessing the cubby box.
This is the genuine BMW item.
Even has 'L' and 'R' stamped on the brackets to aid fitting by numpties =))
£150 collected from Staffs area. Great all round condition and functions perfectly as designed.
Question via PM please.
I've just found out to my cost there are two versions of this deflector. This one if I'm correct is 700mm between the pins and the one I bought off ebay is 750mm between the pins so make sure you measure them!! Not sure how you can tell which version fits in which car?
Luckily I have an engineer that does some work for me that is going to modify the one I've just bought to fit my 2000 1.8
