I have for sale a full set of genuine BMW roll hoops together with all trims. These are the original type approved hoops that add structural integrity to the vehicle and actually function as expected in the unlikely event of a roll over, in my opinion still look the best too. After market ones will probably not afford the same level of protection when needed, in the words of Ted Moult (for those that remember him) "you only fit them the once so fit the best" !! These will fit any model or year of Z3 as a retrofit item and come complete with all you need to do so, all trim panels are in excellent order with NO broken tabs etc and come complete with the required fixings (all you need is a torx bit). The all important inboard mounting posts are also included.
For those that feel they may struggle to fit them I am quite prepared to do that for you if required.
Also available separately if required is the original BMW mesh type wind deflector, the advantage of these over the Perspex type is they fold / roll up into a very small area and therefore take up little room. The centre section unzips and drops down for better rearward vision when the hood is up enabling the deflector to be left in place permanently.
The roll hoops are a popular retrofit item and the price has to be £280. Collection from either Staffs or Leicestershire or at a pinch could be posted but wouldn't be cheap.
