gearbox oil
Discussion in 'Z3 Roadster & Coupé' started by richone55, Nov 19, 2014.
  1. richone55
    richone55 Newbie
    Nov 18, 2014
    7
    3
    3
    can someone tell me what oil and how much will i need to fill my gearbox on my z3 3.0 please
  2. David
    David Zorg Guru (III)
    Supporter British Zeds
    Sep 16, 2013
    827
    873
    127
    Shoreham-by-Sea, West Sussex
    Model of Z:
    Z4 3.0si Sport
    This is @Southernboy 's area of expertise, I'm sure he'll be along shortly with some advice.
    • Like Like x 1
  3. t-tony
    t-tony Zorg Expert (I)
    32,218
    15,158
    220
    Model of Z:
    Z4 3.0 Auto
    To be honest Richard, you are best served to go to your local retailer be it Andrew Page, Euro Car Parts or whoever and ask them what grade oil and what volume you need. This subject has been covered on here several times this last year and will only confuse the issue IMHO.:)
    • Agree Agree x 2
  4. richone55
    richone55 Newbie
    Nov 18, 2014
    7
    3
    3
    will do thank you
  5. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,353
    675
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    The TIS usually quotes gearbox fill as 1.1 litre but I have seen 1.3 quoted on some sites. There should be a coloured label on the gear box showing oil type required.
    Opie oils are very good for brand recommendations. http://www.opieoils.co.uk/
    • Like Like x 1
  6. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,537
    2,569
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    +1 for opie oils, give them a call and they will see you right.
    • Like Like x 1
  7. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
    Gearbox does not take oil. It takes ATF-based fluids, often called MTFs, with a viscosity of around 7.5, of which there are several.
    • Like Like x 1
  8. vintage42
    Dec 24, 2013
    227
    66
    39
    My box shows oil on the fingertip at 1 quart so I don't buy a second quart. I looked at http://www.opieoils.co.uk/c-1432-atf-automatic-transmission-fluid.aspx and did not see anything of an MTF nature.
    BMW specifies a fluid a viscosity around 7.5.
    Here's a list of fluids meeting the viscosity specs, available in the US. Links are provided only to show the products. Pentosin is a German company so I assume it markets to the UK.
    BMW MTF-LT-1 (stock original fluid, replaced by BMW MTF-LT-2, made by Pentosin)
    Viscosity at 100C = 7.5 cSt
    Dexron III (an original replacement fluid)
    Viscosity at 100C = 7.4 cSt
    BMW MTF-LT-2 75W80
    Viscosity at 100C = 7.7 cSt
    http://www.ecstuning.com/BMW-Z3-2.8-...rain/ES197386/
    Pentosin MTF 75W80 (same fluid as BMW MTF-LT-2)
    http://www.ecstuning.com/BMW-Z3-2.8-...ain/ES1893847/
    • Like Like x 3
  9. richone55
    richone55 Newbie
    Nov 18, 2014
    7
    3
    3
    thanks for all your help
  10. Rudyrov
    Rudyrov Zorg Legend
    Jan 29, 2014
    108
    69
    Bothell, Washington
    Model of Z:
    2.8 L Roadster
    I used Royal Purple Synchronous Synthetic Transmission fluid a while back, worked great and helped to improve the smoothness of the shifter. I believe I bought 2 quarts.
    • Like Like x 1
  11. t-tony
    32,218
    15,158
    220
    Model of Z:
    Z4 3.0 Auto
    How much actually went in Rudy? According to Carweb a 3.0 manual gearbox should hold 1.2 ltr.
    • Like Like x 1
  12. Rudyrov
    Rudyrov Zorg Legend
    Jan 29, 2014
    108
    69
    Bothell, Washington
    Model of Z:
    2.8 L Roadster
    A little over 1 bottle. The calculation says 1.3 qts. I gave ha friend the balance of the second quart, so cant go back and look...Sorry.
    • Like Like x 1
  13. t-tony
    32,218
    15,158
    220
    Model of Z:
    Z4 3.0 Auto
    No worries thank you.
    • Like Like x 1
  14. vintage42
    Dec 24, 2013
    227
    66
    39
    I replaced the 17-year old original "lifetime fill" with RP Synchromax and the fresh clean fluid was an improvement. I am sure any of the other MTFs of the same viscosity would feel the same.
    The Bentley Manual says the transmission will hold 1.1 quart. I bought two quarts, but after feeling with my finger tip that the first quart brought the level up to the filler hole, I didn't open the second quart.
    I suppose the 1.3 quarts figure is a result of people measuring .7 quart left in their second bottle, after the transmission takes the .1 quart and the other .2 quart flows out before it can be stopped.
    #14 vintage42, Nov 20, 2014
    • Like Like x 2
    • Funny Funny x 1
  15. richone55
    richone55 Newbie
    Nov 18, 2014
    7
    3
    3
    thank you i will get it done this weekend and thank you all for your help
