Gearbox oil change
Discussion in 'Z3 M Roadster & Coupé' started by badman gee, Apr 3, 2013.
  1. badman gee
    badman gee Guest
    Hello all,
    I'm going to change my gearbox oil.
    A couple of questions:
    Please confirm the best oil to use and the best place to buy it.
    Also do I need any other parts I.e seals etc. (part numbers would be handy to have)
    Apologies if this has been done to death.
    Many thanks
    Mark
  2. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,204
    707
    156
    Wakefield
    Model of Z:
    ///M Roadster
    The very best stuff you can get Mark is Royal Purple Syncromax available from these guys but it aint cheap, good stuff though;
    http://www.iridiumengineering.co.uk/2013.html
    Failing that the standard Castrol 75w90 stuff or Amsoil MTF from Opie oils.
  3. badman gee
    badman gee Guest
    Thanks Ian.
  4. Jamezee
    Jamezee Zorg Guru (I)
    986
    219
    97
    Peak District
    Model of Z:
    2.2 sport
    Gearbox oil? Are you going to actually drive it? ;)
  5. TWO
    TWO Zorg Legend
    230
    239
    74
    Chelmsford
    Model of Z:
    Z Sport Roadster 2.2
    I had the gearbox oil changed last year using Amsoil Synthetic Manual Transmission Fluid MTF-1 supplied by Opie.........made a big difference on the gear changes....a lot smoother :)
    A mate did the oil change as I seem to remember it was a bit of a pain to get access to the side filler if you did not have an oil pump.
Share This Page
