I'm surprised Gary did
What's more worrying is where did they go?
This is prime example of why I prefer working alone or the help of one other.
I'm just going to go and sit in the corner of the room for a whileWhat's more worrying is where did they go?
Lee thinks he has a source, but will PM you later if we get stuck!if all you need are the large cupped washers Gaz I might easily have some spare ones at work. If you can't get any let me know what size and hole diameter they are.
My money is that they are in the dust cover tubeWhat's more worrying is where did they go?
They are common across 3 series, Z3, Z4 and Z8 so should not be too hard to track down.Lee thinks he has a source, but will PM you later if we get stuck!
My my, searched as hard as I can they both look the same! Even tried the old glasses. Are you sure there's a problem?? lol JIMWell that was a fun journey this morning. Looks like one of the new replacement shock top mounts has failed. About 15 miles from home after dropping my daughter at school, and started getting a banging when the passenger rear wheel hit any imperfection in the road. Felt like the rear end was going to fall off when I hit a manhole cover... Couldn't see anything by the side of the road so limped home carefully, but noisily!
Couple of likely options to check, first being the shock top mounts (I could see the shock was still fixed at the bottom)
Lets have a quick round of "spot the difference"... No prizes... It's just for fun
Drivers side:
Passenger side:
