Will get back to you when light comes back on as I pressed erase ,sorryHi Raddy,
Does it have a code with the error message? The codes are usually more helpful than the descriptions!
Gary
OK, it's possible someone may be able to answer with the description you gave. I'm just used to the fault codes that's all!Will get back to you when light comes back on as I pressed erase ,sorry
Just done a quick search on code lists for `fuel trim' - came up withHi Raddy,
Gary
Just got info- code PO 170 fuel trim bank one - and code PO 130 O2 sensor circuit bank 1 sensor 1 any help gratefully appreciated , just want her running right very embarrassing at momentJust done a quick search on code lists for `fuel trim' - came up with
- 2882 Fuel Trim Bank 1
Doesn't mean anything to me but it may help.
- 2883 Fuel Trim Bank 2
Read more at http://realitypod.com/2012/06/bmw-c...ist-e36-e46-e90-and-more/#uplO48gZuXBx1Fvo.99
I can imagine that's wearing thin.. I'm guessing its going to be one of the sensors, but not 100% sure myself...Cheers Gaz fed up of getting honked at lol
