I tried to buy new but bmw said there were none available in uk and in Germany and the supplier had no lead timeVery hard to find as a second-hand part. Most like yours are rotted out. But you may get lucky.
They are also difficult to remove (and of course fit).
You might need to bite the bullet and buy new like @Z3I
https://zroadster.org/threads/tank-straps-good-news-bad-news.21350/
Could do but the old ones aren’t good enough to make a template from ideally need a set tbh thanks tho might be worth a try if nothing comes upThey don't look like they would be too hard to make out of some stainless strapping
I ordered both straps today at BMW one is available now the other is due in Germany with BMW Feb1st so they advised me I will have both by the 8thI tried to buy new but bmw said there were none available in uk and in Germany and the supplier had no lead time
Really need them I’m running out of options
Well you got told a porky as evidenced by feedback from othersI tried to buy new but bmw said there were none available in uk and in Germany and the supplier had no lead time
To be fair most of the rust you see on the underside of a Z3 is likely to be surface rust. On things like the front subframe, chassis brace and sway bar for example.As you read elsewhere, I already have the short strap delivered, with the 2nd longer strap due early Feb.
The original product wasn't really up to being subjected to salt and water over such a long time, with a sponge glued to it to keep the water there. They rot quite quickly, as does all the parts under the car. To replace easily you need to remove the rear beam, I was lucky to get help from Lee and co on this task.
Good luck!
I was just going to post that and claim my finders fee.
Ha ha! I'm only joking about selling them! Anyone can have them for free for templates!I was just going to post that and claim my finders fee.
I can vouch for the seller @Z3I is a top bloke but he may forgotten his glasses when inspecting this part...
I’m amazed you still have them and they haven’t crumbled to dust already!Ha ha! I'm only joking about selling them! Anyone can have them for free for templates!
