Fuel rail
Tomk
Hi all
Need a little advice, put my engine back (replacement )etc etc went to start it and the fuel rail squirted out petrol. I thought I’d put it back together properly but obviously not. Could it simply be I haven’t got the injectors sitting properly? Or have I forgotten something?
Thanks in advance.
Rudyrov
Phoenix, AZ
2.8 L Roadster
The fuel rail has high pressure fuel at the fuel rail feed, at the return and at the injectors when the engine isn't running. Check the seals and "O-rings" at those places first. Chances are you didn't put an O-ring or a seal back at one of those locations.
Zephyr
Hi all
Thanks in advance.
What engine?
the four pots have a sneaky little oring that bobody notices when dismantling.
no 12 in the photo.
ask me how I know...
Delk
Hemsby Norfolk
Z3 2.8 real widebody
The injector set up is similar to he 4 cylinder. Injectors are held into the manifold with a clip and the top of the injector has an O ring on it. Could be a hard o ring or cut it. You can get new ones easy enough.
And when you replace them make sure you lubricate them before refitting the rail.
