Fuel injectors and vacuum connections generally
Steve Medlock
Tenterden, Kent
I'm doing the manifold swop at the moment and as I'm waiting for parts to arrive, I'm cleaning up parts. I'm going to replace the O rings on the injectors but not sure if I can use normal silicon grease on these and other manifold connections or whether there's something else I should be using please?
Steve Medlock
Tenterden, Kent
OK after much internet searching :
Just use petrol / Don't whatever you do use petrol
Just use some motor oil / Don't even think of just using motor oil
etc etc ....
But generally silicon grease seems to be OK and maybe lithium grease is OK too....perhaps.
It makes sense to use a lubricant that is used in the environment the pieces are in. So engine oil is what I use to lube injector seals and any tight vacc. pipes.
Steve Medlock
Tenterden, Kent
OK thanks for the feedback chaps. The problem I was having was that for every expert opinion, there always seemed to be a corresponding expert counter-opinion on this. The injectors were in really tight - probably hadn't been touched in 20 years. Just want to get them back in without damaging the new o rings.
I've never had any issues with ones I've lubed with engine oil Steve. They do get tight, I've seen injectors break before coming out in the past.Petrol as a lubricant would work in my opinion as it would evaporate anyway.
