For Sale: 1 new and unused complete SPAX coil over kit for a Z3 (excl ///M), lowers front 35mm - 55mm and rear 30mm. c/w 28 stage adjustable damping both from and rear.
I am selling this kit as I have decided that I do not want my Z3 any lower than stock. The rear shocks and springs were fitted on the car to check fitment/stance etc. but the car was not used with them on.
The price for the complete kit is £575.00 delivered to the UK, see below, this kit new retails for £649.99 + Postage from either Demon Tweaks or SPAX, which includes a £100.00 discount! (priced today 25th March 2012)
Any questions send me a PM. Payment via PayPal, or cleared cheque.
Spax Website RSXSPAX Website said:excl. M-Roadster---100% Stainless Steel Height Adjusters-KRYPTON Filled GAS Dampers-Ride Height Adjustable on the car WITHOUT Dismantling-Dampers Adjustable on the car WITHOUT Dismantling-Front with height adjustment and rear with fixed lowering-If you want the ultimate suspension kit to transform the handling characteristics of your car and to adjust the ride height too, then SPAX RSX is the answer. RSX kits contain all of the key features and benefits of our PSX kits, plus allow you to adjust the ride height of the car using Stainless Steel Height Adjusters. RSX also allows you to set the corner weights of your car, which means you can control the weight distribution, improving the balance and grip of the car. Some suspension kits may give your car cool looks and adjustable ride height. SPAX RSX Suspension Kits deliver SO MUCH MORE! SPAX RSX kits contain 4 uprated, shortened, 28 stage on-car adjustable dampers, matched to a set of Chrome Silicone race type springs. RSX dampers are uprated, shortened and pressurised with Krypton gas. This ensures that high speed performance is ultra stable, fade free and therefore significantly improved. The result is maximum cornering speed and traction, minimum braking distance and roll. Adjustable for ride height on the car, with no dismantling. RSX is ideal for track days and fast road applications. RSX kits are designed, manufactured and tested to the strictest German T�V quality standards. Each and every RSX damper is fully Dyno Tested to ensure you get 100% performance, 100% quality, 100% guaranteed. NEW Stainless Steel Height Adjusters and Spring Seats ensure no seized components and long life. Dampers and springs are safety critical parts of your car that can save your life. Optimal handling results in better driver control and shorter stopping distances and this leads to a safer and more enjoyable drive. SPAX's massive buying power and "Factory Direct" pricing allows you to buy this premium product at second to none value.
