Brrrr. Looks cold outside. Best solution is to phone in sick and stay in bed.A few times recently my boot lock has been frozen and I’ve not been able to press it in to open. What’s the best lubricant or product to treat it with to prevent this?View attachment 328443
Good suggestion, but I don’t use my Z to drive to work. I get annoyed if I can’t go out for a breakfast run on a cold weekend morning!Brrrr. Looks cold outside. Best solution is to phone in sick and stay in bed.
Gave it a good soaking with silicone spray with the boot up. Hopefully that should do it. Last time it got stuck a few weeks ago I freed it up with WD40, but something made me think twice when it happened again this morning.Silicone spray.
AntifreezeA few times recently my boot lock has been frozen and I’ve not been able to press it in to open. What’s the best lubricant or product to treat it with to prevent this?View attachment 328443
What could you possibly know about antifreeze?Antifreeze. OK I'll get my coat..
Nice retort... I was going to suggest, salty water. But realised you guys in the mother country might be a bit sensitive about that....What could you possibly know about antifreeze?
Liar, you don’t have a coatNice retort... I was going to suggest, salty water. But realised you guys in the mother country might be a bit sensitive about that..... Got my coat and leaving now...
Yes, it seems like it’s pushing the button that’s the problem, as opposed to the lock itself.Did you spray the push button itself?
And you need to open the boot er, . . Oh yeah. to put the 'snowman' soundtrack cd in the changer . . .Good suggestion, but I don’t use my Z to drive to work. I get annoyed if I can’t go out for a breakfast run on a cold weekend morning!
Jammed up with ice, or thermal shrinkage issue ?..Yes, it seems like it’s pushing the button that’s the problem, as opposed to the lock itself.
I normally leave the hairdryer in the boot thoughIf all else fails buy a 12v hairdryer you'll find most z3 came with a hairdryer accessory plug near the gearshift![]()
Stephen.
