- Joined
- Oct 26, 2014
- Points
- 181
- Model of Z
- Z4 coupe sport.
"Tony"------------------------------------get stuffed.----I'm watching fella, but you still need someone to sit in it for promo pics.lol.
It's good stuff, was very satisfying 'making' the spoiler with my son.Purchased another roll so watch this space.
Thanks Zedonist I had an idea I was barking up the wrong tree, wouldn't go down the air root, but fully understand that there has to be some sort of compromise. Well that's all clear to me now so cancel B4s order B6s for the rear, thinking change to matched H&R springs as well that way I will be fitting something that's tried and tested. Roy.Remember the dampers do exactly what it says on the tin, they dampen. That is they prevent the spring from oscillating or bouncing, fitting stiffer springs with standard dampers will give you a boat effect, the sport dampers remove this, I'm sorry to say but if you want a sportier ride, it will be at the expense of some comfort, the only way to lower for comfort is to put it on air?
Thought you said that you only had a small garage Roy!Just in case you might think I'm biased against AIR, I've tried it,heres proof. Maybe not exactly air but defo up on something. View attachment 18742
