Front screen upper trim (inner)-help please
jonco
Chester
'98 1.9 Auto
I'm sure a number of you have already done this one - so advice please.
I've just been running a dashcam cable from rear view mirror along the upper screen, down the A frame to console. Side panel levered off ok. I then removed sun visor mounts which appear to secure the upper trim in place. It feels/looks as if the trim should then just lever off but I got cold feet incase there was something else holding it and I damaged it.
With the trim loosened I have managed to tuck cable in, but only just enough to hold it and it may drop back out with movement.
Cheers
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Wrap some electrical tape round the cable to make it thicker and it will wedge in better. It's what I did
jonco
Chester
'98 1.9 Auto
I'm pretty sure there is a screw under the interior light bulb too
Thanks Andy - I'll have a look at that tomorrow. When you peel the rubber seal back above the light there are a couple of recesses which look like clip points but it's not clear.
spurs fan in a coupe
Not going to have a chance to check tonight, but I think you can ping the cler plastic cover off, then remove the actual bulb and a screw/bolt is under there.
