hey gang,
I thought I would swap out the front sway bar bushes - and then I had this bright idea of swapping all of the bushes, control arm and anything else I could find that looked old & cruddy!!
So the sway bar bushes were so easy!!! I though, great, the rest will come apart easily after spraying them with the usual rust remover/penetrators...
I ended up wasting an entire afternoon trying to undo just one nut!!
The one that goes from the control arm up through the crossmember/subframe.
Can anyone explain the easy way to do this one - I can't get decent leverage on it - there must be an easy way!!!
Is it worth me dropping the subframe? Is it simply undoing the bolts?
Thanks
Thanks
