Front control arm bushes
Sajk
Hi, does anyone know if meyle make an m control arm bush? My parts supplier lists it but the picture shows a bush with no offset. I did try the meyle website but could not find anything.
Think I had similar issues locating them for mine and ended up going with the Powerflex ones with the additional caster angle. Been a while now, but I bought pretty much everything else from Meyle except these.
Sajk
Thanks for the reply. How did the powerflex do from a NVH point of view?
My objective is to get some sharpness into the steering. This car has not gone far, about 72k kilos but there is lack of immediate response in tye steering. This was fixed in the z3 by adding z3m front control arm bushes.
I’ve got various power flex bushes around the car and don’t find any problem with noise or harshness other than what you’d expect on poor UK road surfaces. I’m also on BC coil overs and every suspension bush and component has been changed - so it will probably cope with a few poly bushes thrown in the mix!?!?
