Hi All
Have replaced all the bushings on the front for Power flex Bushings except the FRONT ANTI ROLL BAR MOUNTING. I just jacked the car up knowing i needed to measure it had the VERNIER on it coming up 24.5 do i get the 24mm ones and squeeze them on or 25mm i would probably order the 25mm if left to my own devices but just thought i would check Incase you want/need them tight tight
Cheers Dan
Cheers Dan
