Wanted Found - Z3 OBC facelift
Alin S
Wantage
After buying an OBC on eBay which isn’t powering on, I am now after another one which actually works … are there any available on the forum?
As far as I understood only the faceplate is different between the pre and post facelift so I think I can use either.
Best regards,
Alin
Andy @Iain C was looking for a face-lift one a while back not sure if he ever sorted it .
Since you mentioned you have both I thought I'd tag him into this thread .
Stephen
Face-lift model ones are desirable and hard to find took me a couple of months to find one had bought a full pre face-lift set ( obc , switch temp sensor) and ended up paying as much again just for the round obc :(.
Stephen.
@Alin S I think you are right and it's just the front plastic that's different which gives you a slight advantage as you have that piece on your non working one make it easier to obtain one .
I retrofitted an obc to my Dakar and all I did was plug in the outside temp sensor fit the replacement indicator stalk with te built in obc switch and removed the clock found the different multi plug fir obc plugged in all working straight away .
Stephen.
Stephen
Thanks Stephen for thinking about this. I managed to get one last year and its been working fine since then. Appreciate the note though mate 👍
I think I have a facelift OBC going spare. What's the typical selling price?
