- Joined
- May 29, 2021
- Points
- 4
I have recently had a problem with my temperature skyrocketing with no apparent explanation. Before this it was driving fine for short and longer journeys for about a year without any issues. It is a 1997 Z3.
I will start by saying that I have bled the system, the heating seems fine and the car has a new radiator, thermostat, water pump, temperature sensor (and a few other hoses etc) since 2019. Oil level is fine, oil is clean and no traces of water.
I first noticed the issue when I entered the motorway and it temperature shot up when I got up to 70mph. As I eased of the gas it came back down immediately, but when accelerated again the dial went straight up to red again so I limped off the motorway and she was fine.
Since then I have had the same issue several times but driving round town at 20-40mph. The gauge starts flickering erratically. If I keep driving for a minute then the temperature eases back and settles again. At idle she has no problem. When the temperature rises it does not do so gradually, it shoots straight up into the red as high as it can go and will cool down almost as quickly.
Has anyone had this problem? My next step, when I find the time, is to flush the coolant system incase there is some debris causing a small blockage. I wanted to see if anyone had any advice first.
