Flat battery
Sean d
Lincolnshire
Just been out to check the Z, opened the garage pressed the button to open the car and dead, only gone and left the lights on after yesterdays run :mad::mad:
Welcome to the club usually it's the boot light is left on when I don't shut the boot properly. If you leave a door open it won't lock but boot open it still locks.
Bad luck Sean:(. I should check your lights on warning buzzer (if you have one). If I leave the light on and switch off the ignition I get a warning sound. Hopefully with a full charge you will be on the road again. Best of luck:thumbsup:.
You left your side lights on at Tony's run mate so I turned them off.
I do have the warning sound that sounds like we are going to defcon 1, problem is that I don't notice it anymore and I'm forever leaving them on, its these dam halo's, they look so good I use the lights all the time :D
mmm perhaps you could change it to defcon 5 may be a bit gentler on your ears=))
Its since I fitted the after market stereo, that alarms to let you know you have left the front on so I just ignore it as its garaged and I think it takes my ears off the light alarm.
You need a list Sean, I like lists, need them at my age=))
Perhaps you need a new battery in your hearing aid Sean.:ymdevil: Any way charge the car battery up, sure things will be fine.
Mike
