Fitting my new cruise control
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Today I decided to have a go at fitting the cruise control to my 2001 2.2 Sport Z3.
The parts were purchased from Sopers for £170.26 inc discount and delivery.
There are 3 parts to order.
Interface B65.71.8.380.054
Switch B61.31.8.360.926
Knob B61.31.1.390.968
Tools required are philips screwdriver, sharp stanley knife and some small cable ties to keep everything neat. A small torch is also handy for searching under the dash for the pre fitted plug used for the cruise control.
Fitting....
First remove the panel under the steering wheel. This is held by one screw underneath. Gently squeeze the two sides together and it should come away easily.View attachment 87655
Using the knife, cut out the pre marked panel as shown above.
Next drop the lower trim panel by removing the three retaining screws so that you have access to the area below the steering wheel.
Now simply push the knob onto the end of the stalk and slot the stalk into position on the steering column. The slot is already there and it simply slides into position. Feed the wire back around the top of the steering column to the other side and plug it into the interface. Make sure it is the right way round!
Now, using the torch, look up inside to find the small white plug which fits into the other side of the interface. Mine was easy to see, but I am told some are quite well hidden! Here is where mine was lurking.
Now you can pull the plug gently towards you. Mine came down easily but some might be taped up, which means unravelling the tape first.
This plugs into the socket on the interface.
On some cars there is a bracket fitted around the steering column with slots which allow you to secure
the interface and the large white plug socket to it. This was not in my car so I used very small cable ties to tidy everything up.
Next I positioned the dust cover and sponge pad around the cruise control stalk, ensuring that the dust cover was tucked up inside the top panel which houses the wiper controls.
That is about all there is to it! Everything is already in place for you to simply slot everything into position.
Before repacing all the panels I test drove the car to ensure everything worked properly..
All in all, an easy upgrade which took around 25 mins to complete.
Good info and description for those doing this upgrade :thumbsup:
Brian4
Near Grantham
Z3 3.0i Auto
Very easy upgrade on the M54 engine ones as they are flybywire. Did ours about 4 years ago.
Now you can get annoyed with drivers who can't maintain a constant speed
  • Like
Reactions: Lee
Dalek
Z3 2.2i Auto
I must admit I was surprised on just how easy it was. No excuse for exceeding the speed limit now!
Brian4
Near Grantham
Z3 3.0i Auto
You can still exceed the speed limit very easily just put your right foot down and off you go even with the CC on
motco
Chilterns
Z3 2.2i Sport
I find that on motorways the mental disconnect tends to be soporific. In SPECS zones and in 30mph zones it's invaluable.
hard top
Dutch Zeds
Netherlands
Great write up and photos Dalek :thumbsup:
I had cruise control on my M44 1.9 and to be honest, never used it :bag:
But The Land Of Clog is a small country with lots of traffic, so speeding is not that easy to do often.
Well done Paul. I fitted CC on my Z4 and I use every day.:thumbsup:
Brian H
Killin
E36/7 3.0i - E85 Z4///M
It is a satisfying job well done, I did a write up a number of years ago but cannot find it now.
the Nefyn cat
2.2i Sport
Blimey, the bits have gone up a bit in price since I did mine. Still worthwhile, mine doesn't like cruising at 70 or so, even worse when we went to Ireland a couple of years ago and the motorway limit is 120 kph. Maybe it's just me but it wouldn't stick to a legal speed, and I didn't want to go breaking the law. Oh no, not me.:whistle:
eff1guy
Gt Wyrley
Z3 3.0i Sport Roadster - Auto
@Dalek Great little write up, fitted mine the weekend and this was invaluable took me 30 mins max. :thumbsup: Picked up the stalk recently on here for £20 and got the interface from the stealers for £65.83 with discount
Dalek
Z3 2.2i Auto
Glad it helped. A very useful upgrade, I use it a lot.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Good work guys
GeoffZ
M44
Thats a great upgrade for the money. Do you know if this is applicable to the M44 engined car?
2.2 & 3.0 Sport
...Do you know if this is applicable to the M44 engined car?...
Don't think so Geoff. I did the same mod on my 2.2 a few years ago. Both mine and Pauls have the M54, fly by wire engine.
