How To Guide Fitting E46 arm rest Z3
eff1guy
Gt Wyrley
Z3 3.0i Sport Roadster - Auto
Got mine a couple of weeks ago, have cut it down but still need to get the console out and get it fitted. Do you have to get the whole centre console out or just the bit from the gear lever back? :nailbiting:
mwpe
Camberley
You need to take the whole console out, it is all one piece.
eff1guy
Gt Wyrley
Will have to knock myself out getting the gear selector off again then =)) Only took it off yesterday to fit a new shiny one from the Stealers
eff1guy
Gt Wyrley
Agreed and a great little guide, all that's missing is a "How to get the Console out for dummies so they don't break all the clips on switches etc" feature :whistle: I'm a bit daunted by this, is it easy to remove?
Sean d
Lincolnshire
Its quite simple but there are some hidden screws, there is a how to somewhere. all switches just push out
eff1guy
Gt Wyrley
Found the one under the ashtray, a little search on YouTube has revealed 2 more once the radio is out. I'll do a bit more research before I plunge in
Sean d
Lincolnshire
Yes, the ones behind the stereo are the secret ones, you then have to ease the heater controls off as they are clipped on
eff1guy
Gt Wyrley
Thanks Sean. What have you used to give the nice sheen to the black area of the armrest & the area of the console it's attached to? They have a thin film of some sort of rubberised finish on them at the moment but the finish you've got on there looks great :thumbsup:
Sean d
Lincolnshire
I scotch brighted them and used satin black out of a rattle can
Mazza
Bognor Regis
Another day another parcel....:) ( luckily didnt end up with two of them!!!)
Now need to be brave enough to start hacksawing it =))
Think I will invest in a new blade first....and print off @Sean d ‘s pictures and pin them up next to the vice.
Not that I lack confidence or anything.......:whistle:
Mazza
Bognor Regis
Well made a start.....its a lot harder than I imagined, as the plastic is hard and difficult to hold, but have got some of it removed.
Of course, I was only joking about printing off Seans pictures.....
..........it was easier to have them on the laptop right in front of me ( hope I’m not infringing any copyrights???) =))
First lump off..
Cut down the handbrake side, but left about 10-15 mm to trim down.
Used some gaffer tape to try to keep it straight on the bit that sits in the tray.
So far so good....but thats it for today. No point rushing it.
From this point, I might start filing it rather than sawing it. ( and get the vernier out to check all the dimensions !)
Sean d
Lincolnshire
First lump off..
I used air tools once I was at the stage you are now, mainly an angle grinder and belt saw, just kept trimming and test fitting in my spare console
Mazza
Bognor Regis
That's an idea, I have a small angle grinder and loads of 1mm cutting discs. Thankyou
Mazza
Bognor Regis
Thanks for the advice Sean,
Just picked up a Backing Pad, and a pack of 10 off, 36 grit fibre sanding discs, Less than £6 for both, from Toolstation. :thumbsup:
Sean d
Lincolnshire
They whip it down really quickly
Sean d
Lincolnshire
The back will need an angle putting on it as the tray that it goes into is angled
