Fitting after market instrument gauges to a 1998 Z3 2.8 (prefacelift)
Discussion in 'Z3 & Z3 M Roadster & Coupé Knowledgebase' started by PeterJ, May 9, 2014.
  1. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    Z3 2.8 Roadster M52B28
    • Like Like x 1
  2. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    I can't work out how to comment on each photo! But the gauges are oil Temp, oil Press & (real) water temp. The A pillar gauge is Air Fuel Ratio (& before you ask, yes, it is all the same car & was converted from Auto to Manual:p
    • Like Like x 1
  3. TaffZee
    TaffZee Zorg Guru (V)
    Supporter British Zeds
    2,086
    1,363
    183
    Near Llangollen North Wales
    Model of Z:
    Z4 3.0 SE
    Hi Peter, more details please, looks good, where did the gauge panel come from.
    • Like Like x 1
    • Agree Agree x 1
  4. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,253
    9,508
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Have a quick view of this video. It shows how to add the images in to the text...
    View: http://youtu.be/qAD2dOMdh-s
    • Like Like x 1
  5. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    • Like Like x 1
  6. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
  7. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    • Like Like x 1
  8. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    choice of gauges important. My criteria in order of priority: 1. White needle pointers (match Stock Speedo etc), 2. Full Sweep 270 degree (electrical, NOT mechanical)) 3. Red background light. After looking at so many gauges it nearly drove me nuts (most gauges have red needle pointers!), I finally settled on STACK Gauges. I choose Water Temp (Celsius), Oil Temp (Celsius) and Oil pressure (psi). Note that is two metric and one imperial. Metric gauges come with metric sensor threads & imperial gauges come with imperial sensor threads, so I needed a 'imperial to metric' adaptor for the Oil Press gauge (psi). I choose psi because ...well, just looks & reads better than bar!!. I could have purchased the 'Pro-control' gauges, but did not like the look of the ugly two buttons on the face so went for the 'professional Stepped Motor Analogue (full sweep electric)' as they give the best traditional look that I am after and best readability. The only negative is that they have a white background light instead of red so does not match the OEM instruments at night, but this still looks good as it is on the centre console not by the Speedo etc
    http://www.stackltd.com/instruments.html#Stepper
    • Like Like x 1
  9. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    The Air Fuel Ratio Gauge was put on at the request of RUMA tuning who did my custom ecu remap to tune the engine so that all the mods work together properly. As there was no more room on the centre console, I went for a pillar pod on the drivers A pillar and had both A pillars trimmed in to match when I had the car retrimmed. The Logworks software reads the information directly to the digital (red LED) gauge and can plug into my lap top via a USB socket in the glove box. I would have preferred an analogue gauge, but needed the link to the lap top so had to go for the digital LED. Looks good though
    http://www.innovatemotorsports.com/products/db.php
    #9 PeterJ, May 9, 2014
    • Like Like x 1
  10. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    I was advised to keep the stock clock thing connected because apparently it has other functions, so I hid it behind the centre console (the actual clock did not work anyway) & I was strongly advised not to disconnect it. The switches for the soft top, air con, ASC were easy to move and as I have now completely removed the ASC system including the ASC butterfly valve in the intake, the ASC button has no function. You can see in some of the pictures that I replaced the old square air con switch with the better looking round button air con switch
    #10 PeterJ, May 9, 2014
    • Like Like x 1
  11. TaffZee
    2,086
    1,363
    183
    Model of Z:
    Z4 3.0 SE
    :thankyou:
    • Thank You! Thank You! x 1
  12. PeterJ
    PeterJ Zorg Legend
    Hong Kong Zeds
    Jan 7, 2012
    147
    188
    72
    Hong Kong
    Model of Z:
    • Like Like x 1
  13. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,991
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    Peterj, nice job and looks factory from the pics! I will be looking at doing this once my car is home. JIM
